I recently acquired a second-hand pair of Beolab 6000s. I noticed that one of the speakers is leaning a little forward on its stand. Looking underneath, I found that one of the bolts that holds it in place was bent (which must have taken quite a bit of force!). I would like to replace this bolt. Does anyone know its dimensions?
Hi
I think it is a 3 mm wide and about 2 cm long.
Perhaps I remember wrong. Then it must be a 4 mm wide screw. Still about 2 cm long.
It is an internal hex screw
Edit: I did remember wrong. Sorry. To be exact the screw is 4 mm wide and 16 mm long.
Hopefully this helps.
you need a screw M4 x16 !!
wilfried
sTeamTraen:
Thanks!
Many thanks!!
