Is there a replacement available for the foam pieces that surround the tweeters? I'm wondering what people do to restore this part since they are typically somewhat degraded or missing.
Hi Noise
Try this link to a Danish Webstore :
https://bekent.dk/selvbyg-hojtalere1/hojttaler-reservedele/kantophaeng-maerker/kantophaeng-bang-og-olufsen.html
On this webside you can see prices for foam and rubber sorround pieces. Please note the site is in Danish language.
Kind regards
lassfi
I don't think the above is what OP is asking about.The tweeter dampers are usually OK, even if slightly deformed by years behind the grill.Have yours disintegrated or are they missing?I can surely find a fair original used pair in the dungeons.
Yes, Martin is right... The ones I have are probably in typical shape, one is split and another with a piece missing. I have seen some amazing restoration work here, and I was wondering if anyone who refurbishes B&O speakers has techniques to make new ones or find replacement materials. The material is interesting, it is soft but still has some spring-back to it, unlike a lot of old foam I have seen in the past.
