Beocenter 7002 vinyl problems
This post has 6 Replies | 2 Followers
redrovery
Posts 6
redrovery Posted: Thu, Jan 3 2013 9:04 PM
Hello I have a Beocenter 7002  which I use daily both to play records and listen to the radio. I am getting some scratchiness/inteference from the speakers but only when I play records, the radio is fine. I have checked the connections on the original B&O speakers and on the Center but they all look ok. Can anyone suggest what the problem might be? Could it be the stylus?
Thanks Richard
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Thu, Jan 3 2013 9:12 PM
If the pickup is the original (or of that age), then it is likely the culprit. The unit probably needs other service too, such as new capacitors, trimmers and adjustments, though.
/  Johan
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jan 3 2013 9:15 PM
Welcome to Beoworld !
Most likely the cartridge.
First try a gentle cleaning, maybe under a microscope, to see if it's just dirt accumulated on the stylus.
Still no luck, replace the cartridge or have it retip'ed by Axel in Germany.
redrovery
Posts 6
redrovery replied on Fri, Jan 4 2013 12:05 AM
Thanks Johan and Martin, might have to buy a new stylus then.
Do you know of anywhere in the UK?
Thanks again Rich
Dillen
Posts 13,191
Dillen replied on Fri, Jan 4 2013 6:10 AM
The only producer, I know of, who makes NEW cartridges is Soundsmith in the US. You can check them out but if your cartridge is worn
but still producing sound, albeit distorted, I would recommend having it retip'ed by Axel. That will give you a superb sounding
cartridge at a fairly low cost.
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Jan 4 2013 3:09 PM
I would back the Axel suggestion as well. You can upgrade the cartridge as well if you wish by changing the tip - I have the Shibata tip on a MMC20S and it is superb.
Peter
redrovery
Posts 6
redrovery replied on Mon, Jan 7 2013 11:21 PM
Thanks Dillen & Peter, Axel looks like the way to go then : )
Cheers
Richard
Page 1 of 1 (7 items) | RSS
