Beocom 6000 and Beocom 5 with Beoline Mark 1 PSTN
piercs01
Posts 2
Silver Member
piercs01 Posted: Wed, Apr 22 2020 3:34 PM
In the midst of a global pandemic, I decided to add landline speaker functionality tor conference calls, in addition to the now de rigueur Zoom and web conference interactions.  I acquired a Beocom 5 with speakerphone, and hoped to add it to my rock solid setup of 4 Beocom 6000 units, which have worked flawlessly for years.  The Beocom 5 would not recognize the old pyramid PSTN, so I thought I'd try adding a Beoline Mark 1 to the mix.  Neither the 6000 handsets nor the Beocom 5 would recognize the Beoline.  Perhaps software updates are required for the 6000 units (currently on US v1.4 and 1.6).  The pyramid base is running v1.3.  The Beocom 5 is running v2.1.  Curious why even the Beocom 5 won't recognize the Beoline 1.  Thoughts/suggestions?
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Apr 22 2020 3:44 PM
Hi and welcome to Beoworld!
Have you had a look here: https://archivedforum2.beoworld.org/forums/p/5422/48822.aspx#48822
It seems that resetting the base PIN to 0000 could be part of the solution.  Otherwise software updates may be required.
piercs01
Posts 2
Silver Member
piercs01 replied on Wed, Apr 22 2020 6:42 PM
Thanks so very much.  I will definitely give it a try!
Page 1 of 1 (3 items) | RSS
