Powerlink 8-pin DIN Male Plugs
This post has 10 Replies | 2 Followers
Flyboy0229
Posts 10
Flyboy0229 Posted: Wed, Apr 22 2020 6:26 PM
Gents;
Where might I buy B&O plugs, please?
V/r
Iverson
Johan
Bolsward, NL
Posts 450
Johan replied on Wed, Apr 22 2020 6:39 PM
Hi Iverson,
I usually buy these at Conrad - at least you have the specs :-)
Johan
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Thanks Guy!
As well as working out cheaper (as my plugs are priced for a pack of 4), I also include a wiring chart for Powerlink cables (all three versions) and unlimited technical support and advice is also included in the cost.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Pat
Posts 152
Pat replied on Thu, Apr 23 2020 9:38 AM
MJBeo
Netherlands
Posts 270
MJBeo replied on Thu, Apr 23 2020 3:36 PM
Hi Steve, these from Conrad look sturdier, with the metal casing, but am I right to assume that sound-wise that does not make any difference from the plastic ones your offering? Cheers
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
Posts 2,165
Hi MJBeo,
My plugs have a metal inner case, so the strength, shielding and sound quality should be the same.  Alternatively, I can provide Rean metal cased 7 pin DIN plugs with gold pins at the same price on request - the centre 8th pin isn't used for Powerlink (even though it is mentioned as an "Overload" wire for Powerlink mk.2) so 7 pin plugs are also OK to use.
Steve.
Johan
Bolsward, NL
Posts 450
Johan replied on Thu, Apr 23 2020 9:18 PM
Johan:
Hi Iverson,
Johan
But I also usually buy complete cables from Steve Cool
Flyboy0229
Posts 10
Gents;
Thx for the advice, ordered some this AM.
Next question:  fine quality solder source?
V/r
Iverson
Flyboy0229
Posts 10
Gents;
V/r
Iverson
W.Frankenberg / Gandalf
Heilbronn / Germany
Posts 290
Here you will find the Powerlink information:
https://www.beoworld.org/beotech/wiring2.htm
wilfried
Page 1 of 1 (11 items) | RSS
