Can your Beosound or Beoplay with 802.11AC connected to 5G channel 149+?
This post has 3 Replies | 0 Followers
plpmminus
Posts 4
plpmminus Posted: Mon, Apr 27 2020 1:00 PM
Can your Beosound or Beoplay with 802.11AC connected to 5G channel above or equal to 149?
Today I restart my router and my Beosound 2 GVA can't find my 5G anymore. I check my router that is running at channel 149 but when I step down to 48 or below it work like normal.
I already check the wifi status at diagnostics and usage function inside B&O app. It shows that the highest channel from my neighbour is 60 (On my MacBook can find another 149 from my neighbour). Over that it is invisible same as my Wifi.
Anyone with Beosound 2 GVA or Beoplay A9 GVA or others with AC Wifi can you test this method for me?
Thank you for your help and answer.
plpmminus
Posts 4
plpmminus replied on Mon, Apr 27 2020 1:53 PM
Easiest way to check out which connected channels are available:
Go to Bang & Olufsen app > Product settings > Configure > About > Diagnostics and Usage > Wireless network analysis > Scan
Then, if you can find your neighbours' network channel with 149 or higher please reply to my post.
Thank you for your help.
plpmminus
Posts 4
plpmminus replied on Tue, Apr 28 2020 2:16 AM
Anyone can confirm Wifi channel for me?
I am not sure if my product fault.
Thank you
plpmminus
Posts 4
plpmminus replied on Wed, Apr 29 2020 1:19 PM
I am also need the answer.
Page 1 of 1 (4 items) | RSS
