How to move a Beovision 11?
This post has 11 Replies | 2 Followers
andy_js
Englandshire
Posts 223
andy_js Posted: Fri, May 8 2020 1:23 PM
My Beovision 11-40 is exactly where it was when it was first installed by my dealer 5 years ago and I'd like to move it a bit, but I can't figure out how to do it safely.  I can't find any instructions online on how to do it.  If anybody can give me some tips I'd appreciate it.  It's mounted on a motorised stand.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, May 8 2020 1:43 PM
I've had success in the past by manhandling the base onto a large sheet of cardboard (an old packing box) and then dragging a mounted TV across the floor (carpet or whatever)  It's a two-person task at least, and you may need to carefully lean the whole ensemble to get the cardboard underneath at the start.  Just be slow and careful.
9 LEE
Eastbourne, UK
Posts 7,218
This is how I've always carried BV10's and BV11's - and I've never damaged one yet.
Two people, one each side, support at the bottom and steady it at the top. Make sure you are both holding it the same way..  I've never worried about the stand being connected either - as long as it's attached securely.
** This image is the nearest I can get to the way I carry them. Laughing
Millemissen
Flensborg, Denmark
Posts 14,680
I guess that depends on, how far you are going to move it.
If just some meters the Guy-way will be fine.
If to another room, the Lee-way would be best.
I’d remove the tv from the stand though, before carrying it.
Place the tv on something that makes it possible to get a good grip on it, when you want lift it to mount it again.....or let someone else move the stand, while you (a two person job!) are carrying the tv.
Carrying it with the stand is for ‘experienced movers’ only.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, May 8 2020 6:43 PM
Addition:
Millemissen:
Make it is some kind of foam which has resistance to weight (to be sure you will not end with a broken glass-front)
a dealer can lent you his service feet for the BV11
Schletti82
Posts 128
Never carry a be 10 or 11 mounted on the floorstand.
the Display easily will be damaged. For carrying unscrew it!
HAMMER1010
Posts 8
HAMMER1010 replied on Mon, May 31 2021 11:01 AM
Would anyone be able to advise me how I can remove my 2009 BV 11 from its stand please.
I need to get it upstairs!!! I’ve taken out the screws at the centre back of the tv but when we lift the tv, the stand comes with it!!
PaulGiles
Posts 218
Slight tilt away from the bottom and lift it off. And make sure the stand cable is unplugged.
HAMMER1010
Posts 8
I’m sorry. I am a total idiot! It’s a BV9,! Same question applies!
HAMMER1010
Posts 8
HAMMER1010
Posts 8
HAMMER1010
Posts 8
Page 1 of 1 (12 items) | RSS
