Volume problems Beocenter 7002
Dylan
Ridderkerk, Netherlands
Posts 1
Dylan Posted: Tue, May 19 2020 5:31 AM
Hi there guys!
I am new to the forum, been using Beoworld for info for years and years now but this is my first forum post. :)
I picked up a Beocenter 7002 yesterday and received one per post mail, so I have 2. Both come with some not mentioned problems sadly. I thought I might reach out to you guys, maybe to get some helpful advise!
Beocenter 7002 "1": Really poor sound output on Phono or AUX. It's really low volume and a bit distorted, FM Radio puts out fine! Really weird problem. At first I thought the AUX input was the problem but the exact same problem shows on playing a record on the built-in record player.
Beocenter 7002 "2": The control panel on the device itself does not work, so I can't turn it on or switch to another input, so I can't test it. It came with the terminal but one of the 2 battery contacts is gone due to corrosion.
Anyone maybe have some experience with these problems? Have some good advice? Thank you very much in advance!
Page 1 of 1 (1 items) | RSS
