Hi Beoworld
I have a Beocenter 9000 in which I have just changed the mute relay in hopes of it being the source of my problem with the speaker in the right channel in speaker 1, but without luck. I have tested it today and it actually seems like the right channel in speaker 2 is also a little lower than left. The left channel works perfectly in both 1 & 2 but the right channel in 1 has no output.
Hope you have some suggestions on what to try next.
