Beovox S 75 Mid Range is faulty
This post has 1 Reply | 2 Followers
speedmaster
Posts 1
Silver Member
speedmaster Posted: Mon, Jan 7 2013 12:49 PM
i have a problem with my Beovox S 75, one of the midrange (behind the plastic cross) is faulty.
Whitch system can i replace?
the only system what i find is from Visaton Type MR 130...
(mein Problem ist, dass eines der Mitteltonsysteme das hinter dem Plastikgitter defekt ist - Ersatz wird wohl kaum zu bekommen sein, was könnte ich als Alternitive einbauen? - das Einzige was ich gefunden habe war von Visaton MR130...Vielen Dank für gute Tipps!)
Thank you for your help
Bernd
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jan 7 2013 2:55 PM
I would suggest getting it repaired will be a better idea. If you replace the driver, you will need to either find a second hand one or you will have to replace both drivers in the speakers and be unlikely to get the same sound.
Peter
Page 1 of 1 (2 items) | RSS
