Hi everybody, I bought a used Beocenter 9000 as a present for a friend of mine. It works properly but the volume of the turntable. He has a modern turntable with a red and white pin connection so I bought an adapter to plug the turntable in. If I connect the I-phone to the adapter the volume works fine, not the same with the turntable. Any suggestion? Thanks, Luigi
