Can’t display pc on Beovision 7-40
This post has 1 Reply | 2 Followers
Joshsutcliffe
Posts 1
Joshsutcliffe Posted: Thu, Jun 4 2020 2:06 PM
Cant get pc to display on beovision 7-40, connected through dvi cable and hdmi converter to pc.
in connection setting av4 is set up with pc as source
Stoobietoo
Exeter, Devon, UK
Posts 692
It sounds like the connections are OK. Have you added PC to the list in your Beo 4? You need to add that and when it is on the Beo 4 screen,  press GO to turn on the TV
I believe you have to set the resolution to 720p on the PC. Just to warn you that you probably won't have sound as the DVI Connector doesn't carry it.
Stoobie
Page 1 of 1 (2 items) | RSS
