Beolab5 and Sonos Connect
This post has 1 Reply | 0 Followers
Therealzion
Posts 1
Therealzion Posted: Thu, Jun 4 2020 8:25 PM
I am trying to connect our Beolab5 to our Sonos Connect (Not the amp version) but don’t know how to do it.
I have a Beo4 remote so its ok I have to turn on the speakers using the remote.
Should I use option 1 or 4?
Can I take a COAX cable from the Sonos Connect to speaker A and a COAX cable from speaker A to speaker B?
And after that the Sync cable from speaker A to speaker B?
Do I still need use the line cable if I use the Digital Solution (COAX)?
PeterBOBP
Posts 133
Therealzion:
A: 1 if you do not have another (b&o) system in the same room 4 if you do (see manual)
Can I take a COAX cable from the Sonos Connect to speaker A.
A: yes
A: yes
A: yes
A: no
See answers above. let us know if it works! Peter
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
