Beogram 5005 tracking has stopped working
This post has 7 Replies | 2 Followers
Jerryege
Posts 41
Jerryege Posted: Sun, Jun 14 2020 8:32 AM
This has suddenly happened since adding an earth/grounding wire.
Beogram 5005 has, after a lot of tickles, been working perfectly. But since adding a ground wire (rewired with a three core cable to give earth back to the wall socket) the tracking has totally stopped. Both the left/right button and the auto opto sensor have no effect. The left/right button does lift the arm but no linear effect.
I'm getting no voltage across the motor terminals when pressing the L/R button. So a bit stuck.
Any ideas? Am I testing for the voltage correctly by going across the terminals and not one terminal to earth?
Any help gratefully received. Hopefully something simple I've missed.
Thank you
Spassmaker
North Germany
Posts 223
Spassmaker replied on Sun, Jun 14 2020 11:30 AM
Hi
Did you open the Beogram for mounting the Ground Wire?
Have you checked the String for the tangential Transport?
It´s a common problem of these Type of Beograms that a small Hook of plastic snaps of the Base where the String is attached to.
Here is a Link for this
https://archivedforum2.beoworld.org/forums/p/27999/221138.aspx#221138
In the Picture it´s Point H which comes of.
You can use a 3mm Screw with washer and Nut and reattach the String in Point H.
Is the Motor for tangential Transport working , Noise from Motor audible?
Motorbelt in place and not loose?
Check the above Points and let us know what you found out.
Best Regards
Chrischi
Jerryege
Posts 41
Jerryege replied on Sun, Jun 14 2020 11:55 AM
Ground wire is connected to the chassis on the inside of the beogram.
Wire is all in place and operates perfectly.
This is an issue with the motor not running. There is no power to the tracking motor.
Why I do not know, that is the question.
lawrencejmcook
Posts 742
Jerryege:
Hi Jerryege,
What reason did you have for grounding the turntable to the mains Earth? I understood that most modern B&O devices (with odd exceptions like BeoLab 5) are double-insulated and therefore do not require connection to mains earth. They should have a symbol on the safety label to indicate that: a square within a square.
The ground from the turntable (in the DIN plug) should connect to the earth connector on the amp (this is all taken care of if you connect the Beogram to a BeoMaster with the 5-pin DIN).
Lawrence
Jerryege
Posts 41
Jerryege replied on Sun, Jun 14 2020 5:54 PM
Basically lots of static and a light tingling when you drag your fingers over the surface of the body.
Interestingly the beomaster is also not earthed so cant see how the earth on the masterlink will earth anything apart from the BG to the BM.
I took a lot of advice and apparently a lot of people have done the mod and swear by it.
I originally had the BG linked by an earth wire to the BM's ground screw after earthing the BM in the same was with a three core cable. All worked well and the static was gone but the ground lead was 'messy' so decided to rewire and give the BG it's own earth.
lawrencejmcook
Posts 742
Jerryege:
The point of connecting the Beogram’s earth to the Beomaster’s earth (and both with no mains ground) is to put them at the same earth potential.
But as you say, you’ve done your homework and had some good results. So hopefully the folks who advised you to take that measure will chime in soon with suggestions for a fix.
Otherwise you can always fall back to your first solution.
Jerryege
Posts 41
Jerryege replied on Mon, Jun 15 2020 5:52 AM
If you mean to revert back to factory and remove the mains earth, I have already tried and still no tracking.
lawrencejmcook
Posts 742
Jerryege:
No - I meant your original solution:
“I originally had the BG linked by an earth wire to the BM's ground screw after earthing the BM in the same was with a three core cable. All worked well and the static was gone but the ground lead was 'messy' so decided to rewire and give the BG it's own earth.”
Maybe Spassmaker is right and something was inadvertently detached. So sorry I can’t suggest anything more.
Page 1 of 1 (8 items) | RSS
