Hello
The original gear of my CDX's lid was obviously broken and I bought a new one to fix it.
My problem is that I don't know how to remove the hinge that prevents disassembly of the mecanism of to access the gears...
If anyone could help with a couple of pics, I should be grateful, I'm definitively not a specialist.
Thanks.
Didier
Hi, Did you ever get this issue resolved ? I had the same problem but I did get there eventually - let me know if you're still puzzled.
Tim
