Has anyone any ideas on removing scratches from the see through plastic part of the lid on a Beogram 3500 turntable ?
I have two about 3cm long, not deep but noticeable.
Thank you and best regards. Bill.
You can purchase clear plastic surface scrath remover kits at hardware stores or very carefully (try a small test section first before entire scratch):
Clean the surface with a damp cloth, rubbing in a circular motion around the scratch. ...Apply a mild abrasive, such as toothpaste, furniture polish, a very small amount of baking soda or plastic polish to the scratch. ...Wipe a clean cloth over the paste you have added in a circular motion.
