Cant Play via iPhone Dock on Beoplay A8
This post has 2 Replies | 2 Followers
HGST
Posts 1
HGST Posted: Fri, Jul 10 2020 9:51 AM
My neighbor passed his A8 to me so I could help him set up AirPlay. First thing I did was plug in my iPad into the lightning dock. It started charging my iPad and I could play some YouTube videos (sound only of course).
Then I managed to set up AirPlay and that works too but sometimes the sound would disappear and come back. Sometimes it wont. Anyway thats another problem. The problem I am having now is when I try plugging in my iPad to the dock, it wont play anymore. Neither will it charge. The play button light goes off the moment I plug it in.
What gives? I dunno how to fix this. Could it be a flaky dock? I also tried my iPhone, doesnt work either. Any suggestion or advice would be much appreciated. Thank you all in advance
Btw during AirPlay, the sound would suddenly stop and sometimes it will come back. Nothing consistent. After I tried it further, it seems to be able to play the whole album now instead of stopping at every song.
mimarko
Posts 1
mimarko replied on Mon, Feb 8 2021 10:05 AM
I have the similar problem with my BeoPlay A8. When I put iPhone or iPad on dock, charging not working and cant play music, also green button goes off. I tried to replace plugged dock and still not working, thats mean the dock module is okay. What could be a problem?
Thanks for help
Marko Mitic
peske1
Posts 1
peske1 replied on Fri, Jan 14 2022 1:47 PM
I have some sort of the same problem. Gradually the A8 would not play from iphones when docking. I went on and off, stopping the transmission. First I thought it was dust i the iphone lightning plug in and cleaning it helped. But know I have the same problem with my new iPhone 13 Pro. Next I'm going to ask B&O and focus on updating the A8.
Airplay and charging works fine, its only the docking.
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
