Can someone explain what parts I'm missing and how the dust cover works. I have looked at some of the posted photos, and it is still not clear to me.
I have the three screws and clips that hold the rear panel to the turntable. The three screws with the square nuts are present, and the spring is intact. There is nothing to retain the spring nor nothing to secure the cover to the rear panel. There is also one small metal "L" piece.
I was able to use a larger washer to retain the spring on the two outer screws. The chassis seems to hold the middle in place. With the spring ends on the bottom of the cover there is nothing to keep them in place and the tension is high.
Any guidance would be appreciated.
Gary
Will this help:
https://archivedforum2.beoworld.org/forums/t/42833.aspx
