Beogram => BL8000 + BV10 + BS9000 ?
Juuhuu
Posts 4
Juuhuu Posted: Fri, Jul 17 2020 9:02 AM
Hi All,
As my girlfriend is a big fan of vinyl discs, i am thinking to get a Beogram for my configuration as i think to be as follow:
BL8000s are connected to the BV10. BV10 is linked in to the BS9000 with ML. So if i get a Beogram, may i plug in to Aux of the BS9000 ? (with an additional pre-amplifier depending the model of Beogram as i read previously in the forum).
Does this configuration will make the music ok to the BL8000s speakers ?
Would it be preferable to directly plug the Beogram to the BV10 ?
Any luck that i can use my beo4 remote to control the Beogram ? Or is there alternate config for it ?
What would recommend as Beogram ?
Thanks all !
Page 1 of 1 (1 items) | RSS
