Can anyone help me find the Service Manuel for my beovision Avant 55 mk1
you not helped with servicemanual because lcdpanel is a parts itselfs and ”and cannot be repaired” and if you thinking you can repair panel there is no problem to open the tv either
I guess you’re right but the manual would help me figuring out getting the panel put from the glass.
the lcd-edgelit panel is Samsung and parts are available for these types.
Take of dekorpanels on back,then plastig covers left and right then
you use tool from bottom of chromedecor and then lift of, then screws around frontglass,and on back to take of the big black metal backside,then take out powersupply,take out speakerbox,take out VE mainboard and interfaceboard for screen, lift of frontglass, and then the 4 screws that hold panel from backside
Thanks much appreciated!
