5500 Turntable Tone Arm advance issue
This post has 0 Replies | 0 Followers
Cardo222
Posts 1
Cardo222 Posted: Tue, Aug 4 2020 12:15 AM
Beoworld,
 I am restoring a 5500 Turntable. I have managed to get most everything working with one problem. The tone arm will only advance a bit before skipping back. I can see the assembly is not moving. The string is attached and the belt is new. It moves when the advance buttons are pressed < > and when you press play. I believe it may be the light sensor or light itself. Can someone tell me if and when the light will turn on while it is apart and running? I would like to know if it is indeed the light or the sensor that needs replacing.
Thank you all,
Rich
Page 1 of 1 (1 items) | RSS
