Beo6 auch "AV"-Taste?
Kopfnuss
Posts 30
Kopfnuss Posted: Sat, Aug 8 2020 11:21 AM
Hallo Leute und ein schönes Wochenende euch.
Ich programmiere gerade meine Beo6. Soweit komme ich ganz gut klar, nur leider kann ich keinen AV-Befehl finden!
Gibt es dafür eine andere Bezeichnung? Danke euch!
matador43
Posts 1,373
matador43 replied on Sat, Aug 8 2020 11:41 PM
Hi, sorry to reply in english but as much as i would, I dont speak german!
If you refer to the AV key like on first Beo4, that is to open audio channel only on a video source you could do two ways :
- Make a macro to activate the source and add a P.MUTE command to turn off the screen.
- Open the AV source with the usual command and change the prefix from TV to RADIO, or any audio only source.
I can't check precisely the syntax for the second solution since i'm not in front of the config tool but i should be close enough to remain understandable.
Page 1 of 1 (2 items) | RSS
