Hopefully someone can help me with the following issue:
For the first time since I acquired my BG 4002 last year, I tried playing some 45 rpm vinyles.
Everything works well up to the needle reaches the disc where it does not move and stays in the same groove or jumps quickly from groove to groove.
I tested several vinyles and the arm weight is set at 1,5gr.
Many thanks in advance
Solved: I set the tracking force adjustment to 1
