Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Maybe connect the CD7000 to a stand-alone MCL2AV via one of its front panel CD sockets, then you'll be able to control with a Beo4 via an MCL transceiver. No need to worry about MCL cable connection, etc, but the MCL2AV would have to be powered (15v).
Then you can either feed the MCL2AV's powerlink output (volume controlled) into the rest of your system, or simply take a parallel line output from the CD players output.
You could then play with the MCL2AV's option settings to get the control that you require using a single remote.
