Beosystem 4 + universal player versus OPPO 105
seethroughyou
UK
Posts 999
seethroughyou Posted: Thu, Aug 27 2020 10:52 AM
In my quest to multichannel from classical SACD and DVD-A / Blu-rays, is there any advantage of a Beosystem 4 + universal player over a OPPO-105. The former is an expensive way. Presumably, I can do channel levels and connect to the surround speakers and my front Beolabs just using an OPPO-105. What would a Beosystem bring to the show?
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Aug 27 2020 11:00 AM
When you start getting into multichannel SACD music, there's quite a lot that the BeoSystem 4 can do. With the BeoSystem 4, you can re-assign the LFE channel to use a height speaker with the "ceiling" role. Also, there are some SACDs that use the center channel for a height speaker. Thus, you can create various speaker groups to use for the correct speaker configuration that the particular SACD requires.
Page 1 of 1 (2 items) | RSS
