Hi everybody,
Yesterday, I noticed that one of my BL 8000s was missing.
The LED is off and no sound comes out of it.
The speakers are old, I bought them in 1996.
I swapped the 2 speakers and it does not come from the connexions.
I remember that my dealer told me that the power-supply module was out of stock at B&O.
So 2 questions:
- What further test can I do by myself to diagnose my speaker?
- Is it possible to repair the power supply module at the component level?
Thanks for you help,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
You’re talking about Beolab 8000 as in the title, right?
Most likely the disintegrating damping foam has corroded one or more of the PCB traces on the PSU board. You do not need a new module just because of that. There are plenty of threads on the forum about this particular problem (I’d find one for you If I were on a real computer).
--mika
Thank you Mika.
You are right, I fixed the typo.
Have a great Week-end,
