Hi
newbie question here :) I have a set of BL18’s which are wirelessly connected to a BEO Transmitter 1 and connected to my Samsung Smart TV through an optical cable. All works well but I would like to add a subwoofer to the system. A BL19 is out of my price range as I am on a tight budget for this. Can anyone suggest a means to connect a powered subwoofer? Is it possible to plug one via an RJ45 cable into the transmitter and if so what subwoofer brands/products could do this?
Thank you
