Hi all.
I'm wanting to get a line out of my beocentre 7000. I'm wanting to send the output via bluetooth or perhaps to an external tape deck.
I've seen a few places online, including this forum that say you need to connect to the TAPE out on the back. However I think that must be for different model as all I see on mine and the manual is the TAPE IN on the front.
I have used this with a converter to stream to the beocentre using a RCA to 5 pin din (I think that's what its called)
Will this work also as a tape out?
I haven't had any luck with it so far. Do I need a special cable?
I haven't been able to track down the user manual for 7000, all the downloads instead link to the schematics.
The 7002 manual says you need a special cable with 2 aux plugs ( 670239 DIN - 627024 phono plugs). But I can see the 7002 calls the front connection it has AUX whereas mine says TAPE IN so it might not work.
It has a headphone out but I guess that's not going to be suitable for what I would like to use it for.
The TAPE IN socket at the front is only an input.And it switches out the internal tapedeck, when something is plugged in here.If your Beocenter 7000 has a blinding plug called "EXT" or "Line in/out" at the back, you can take a line-out signal from there - but it will not have volume control.
Nope, I cant see anything on the back like that.
Strange on mine when I plug into the front tape in, it switches out the tuner, not the tape deck. How odd.
Sounds like I'm stuck then.
Thanks for your help.
