I recently purchased beolab 5s and want to know if i can buy a sonos port and connect the beolab 5s directly using the digital out on the sonos...and wondering what cables i will need to do so...
cheers!!
Hi Wiyum,
Welcome to Beoworld! Yes, this is possible via these 75 Ohm digital cables (one cable from the Sonos to the first speaker, then another cable between the two speakers):-
https://soundsheavenly.com/beolab-5-beolab-50-and-beolab-90/34-274-beolab-5-50-and-90-s-pdif-digital-cable-ofc-with-gold-contacts.html#/4-length-3m
Please note that you will always need a B&O remote control to power on the Beolab 5 speakers before use.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
