Beocord 2000 Problem with Sound
This post has 11 Replies | 0 Followers
aragorn83
Posts 15
aragorn83 Posted: Thu, Sep 24 2020 11:01 AM
(sorry for my english, i'm french)
I try to repair my beocord 2000, i change belts. i can play an audiotape without problem now BUT the sound is a little weird sometimes : it slow down and seem to go left to right and right to left for a few seconds
i try with different audiotapes and i play audiotapes in an other player, no problem with audiotapes
after reading lot of subject about Beocord 2000, i decide to change R8 resistance, C200/208 (name is differente up and down the board) and C408. No change the problem is still here
I try with an "Car Cassette Adapter" this one https://www.amazon.fr/gp/product/B01I02WT94/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
and with this the sound is OK, no problem ! So i think the problem isn't in the sound parts but with the player or motor parts ? (i'm not sure to be clear ?)
i have 13,8Volt at the motor.
Any ideas or what can i check or change ?
Thanks a lot
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Thu, Sep 24 2020 11:16 AM
Did you renew the pinch roller? Often they get spherical and cannot work evenly.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Sep 24 2020 11:25 AM
ProGram:
My first thought too.
Clean tape path, capstan, pressure roller, heads etc.?
Good quality tapes?
And did you fit correct belts or some cheap stuff from China or Portugal? A motor overload can cause this too.
aragorn83
Posts 15
aragorn83 replied on Thu, Sep 24 2020 2:18 PM
the pinch roller seems to be "normal" i don't change it,
I test with 4 tapes and i test with an other player, tapes works
I take belts from china
Dillen
Posts 13,191
Dillen replied on Thu, Sep 24 2020 4:01 PM
Correct spare parts for Bang & Olufsen from China?  Ehh....
The (toy-) belts sold there and in large numbers on Ebay are usually nothing but standard sizes and typically far too tight.
If your motor bearings aren't already worn out from a too high sideways pull (it happens fast with the delicate sinter bronze bearings), I suggest you grab a set of correct belts (beoparts-shop.com) and try again. If the motor has suffered, I may be able to find a good original replacement.
Sorry, but I have seen this hundreds of times with all kinds of different outcomes.
Read more here: https://archivedforum2.beoworld.org/forums/t/38090.aspx - actually, a case similar to yours is also found there.
aragorn83
Posts 15
aragorn83 replied on Sun, Sep 27 2020 2:01 PM
Ok thanks a lot for answers.
i will see it when i have more time.
aragorn83
Posts 15
aragorn83 replied on Tue, Jan 12 2021 3:13 PM
in fact i have a little variation of volt at the motor.
my normal measure at the motor is 13,81 - 13,83 Volt (sound is ok)
sometimes the volt down to 13,68 - 13,75 for 1 seconds , it's when the sound become strange (a little slow)
I make some tests and measure and i am asking me if 13,8V is normal because it's indicated 14,3V
the transistor TR4 is ok ? or maybe he is a little too old ?
I check C1 / c2 / c3 / R3 / r4 / r5 / r6 / r7 / r9
I change c4 / c5 / c6 / c208 / C408 and R2 / R8
thanks a lot
Dillen
Posts 13,191
Dillen replied on Tue, Jan 12 2021 4:17 PM
13.8V is a little low, but should be OK for the motor, - but it should run stabile and the voltage shouldn't drift like this.
Sounds like the motor is (or has been) running rough, (over-)loading the power supply.
Wrong belts?...
Has R8 burned? That would be a clear sign of overloading (ref. the mentioning of this exact component in the link in my post above).
I suggest you replace R8 (note: it's a safety component, must only be replaced with a similar type), fit known correct belts (Beoparts-shop) and lubricate the motor bearings - if not already to late.
If the motor has been damaged PM me or ask at Beoparts for a replacement, - R8 too and any other part you may need.
aragorn83
Posts 15
aragorn83 replied on Tue, Jan 19 2021 11:19 AM
Hi Martin thanks a lot for your answer.
Yes R8 has burned and i replace it by same caracteristic
Before change motor and belt... even if i am not really sure to do this. Because i don't really need to play audio tape, i just like to have something who works fine :) and actually it's work but not totally fine :p
How can "lubricate the motor bearings" ?
Thanks for your time
Ennio
Posts 18
Silver Member
Ennio replied on Tue, Jun 8 2021 2:07 PM
Where to get a belts set for Beocord 2000 tape recorder ?????
Vytautas
Ennio
Posts 18
Silver Member
Vytautas
Dillen
Posts 13,191
Dillen replied on Tue, Jun 8 2021 4:03 PM
For the cassettedeck Beocord 2000 www.beoparts-shop.com
For the open-reel deck, I'm not sure if anybody ever reproduced the correct belts.
Page 1 of 1 (12 items) | RSS
