Hello!
I just bought a newer B&O Beo4 remote control from a third party and it is slightly different than my older version with the buttons it has, such as Media, Aircon, Wakeup. It does not have the LIST button. Is anyone have this particular version of the Beo4 Remote control? And can you please tell me how to connect/link it to my BeoMaster 4500 which I love! I need to be able to at least use it to control the volume and the CD deck.
Thanks!!
Are you sure this is a Beo4 remote please? This doesn't sound like a Beo4 Cinema remote, but it may be one of the special "hotel" remotes that B&O have made with limited functionality. If you can please post a photo of the remote (or the link to the listing where you bought it), we should be able to advise further.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve - that was a double post, already answered at the link: https://archivedforum2.beoworld.org/forums/t/43902.aspx
Thanks Guy!
