I have access to a Beomaster 6500 but the volume level does not work.
Does anyone have any suggestion / solution to change volume level on a Beosystem 6500 ?
Do the other remote functions work?
And what is the BM6500 connected to? Direct to speakers, and if so are they Active (via Powerlink) or Passive (via Speakerlink)?
Most likely a problem with the MCP.
Thank you Martin....
I am not familiar with the term "MCP"
I'm guessing a Master Control .... ?
Master Control Panel = The remote control for your Beomaster.
Thank you for your reply to my question...
Yes, the other remote functions work
I will have to verify how the speakers are connected
(please stay tuned)
