Beosound 9000 connection
This post has 3 Replies | 2 Followers
hprovily
Posts 2
hprovily Posted: Sun, Oct 11 2020 4:22 PM
Dear all,
i am new to B&O and searching for some help with connections.
I like to buy a Beosound 9000 and connect this to my Harman Kardon Enchant 1300 home theatre.
Is this possible?
Thanks in advance for any support!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Oct 12 2020 6:50 PM
hprovily:
Dear all,
Is this possible?
contact Sound heavenly (see this site) for the correct cable
hprovily
Posts 2
hprovily replied on Wed, Oct 14 2020 11:30 AM
Thank you. I will contact them.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Yes, I can help!  This cable will connect from one of the Powerlink outputs of the Beosound 9000 to the 3.5mm line inputs of your HK home theatre system:-
https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-harmony-eclipse-horizon-avant-ng-2017-on-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Please set the Beosound volume to a high level (50-75%) to give you the full range of volume control from the home theatre remote.
You then just need a Speaker Sense Adapter for the Beosound (this plugs into the other Powerlink socket on the Beosound 9000 to allow it to accept commands from the B&O remote control without having B&O speakers connected):-
https://soundsheavenly.com/bang-olufsen/141-2309-beosound-9000-speaker-sense-adapter-gives-remote-control-functions-when-no-speakers-are-connected.html#/18-colour-black
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (4 items) | RSS
