Hello,
Some time ago my Beosound Moment died, the juke box is completely dark, no picture, no sound and can't get access.
I have tried to reset both jukebox and soundheart but nothing happens.
I guess the JB needs to be fix or exchanged.
Anyone of you knows if this problem can be fix or should I order a new JB?
Thnk you for your advice.
BR
I bet the battery has died. It's something a dealer could probably fix. Or if you're technically inclined there's a training video on Youtube that explains how to replace the battery:
https://www.youtube.com/watch?v=vK4PC1hsvpM&list=PLRPmJ785xnMhqM0WuEQbx1VtsUkrfX8SU&index=1
Thank very much
Do you believe that only becuase of the battery the system is not able even to start up?
