Hi everybody.
Maybe someone can help me?
My Beocenter 2300 does not receive any Station above 90,0 KHz just makes a whining sound that gets higher and higher as the frequency raises. Has anybody had this problem ? This problem came overnight.
George.
It's a voltage-controlled system. Start looking for bad capacitors or oxidized potentiometers. A bad solder joint could also cause that.
Hi, Menahem, Sorry for not answering sooner. It was a bad solder joint !
Everything is working fine again.
Thanks for your help.
