Experience in the US with 220 - 230v Beo device?
This post has 10 Replies | 1 Follower
BeoFrederic
Posts 276
BeoFrederic Posted: Tue, Oct 13 2020 12:25 AM
U.S./ Canada Beofriends:
Does anyone have experience they'd be willing to share?  I may purchase a Beolab created for the UK/European market, with a 220 - 230v, 50 - 60Hz power supply.  It will require that I use a step-up transformer here in the U.S.
Anyone with a similar situation?  Does your transformer deliver reliable power?  Sixty-cycle hum, or get hot, or...?  Recommendations or problems?
TIA
Fritz
Posts 272
Fritz replied on Tue, Oct 13 2020 11:43 AM
Pending what you are purchasing, the beolab in most cases can be rewired inside the beolab for 110 volt, on the powersupply board.
jk1002
Posts 278
jk1002 replied on Tue, Oct 13 2020 4:13 PM
I used converter for my BL2500 and Beosound 2300.
Technically there was no issue, No hum, no heat. I bought 3 converter at radio shack back then.
Just note that there are different types of these converter, for hair dryver, shaver they are dirt cheap and would not work for your device. For electronics they typically have much less output and are more expensive which is why I ended up with 3.
Cheers
JK
BeoFrederic
Posts 276
Fritz:
Hi Fritz:  it's a Beolab 2 under consideration, and I was advised by the seller that B&O may no longer offer  a "120v transformer" for the unit, which implies to me that the on-board power supply would need to be swapped out, if it was available.  Is this not the case ?-- can the existing on-board  power be converted to U.S. voltage?  I'd love for this to be true.
BeoFrederic
Posts 276
jk1002:
Excellent, great to hear.  (Or not hear.)
jk1002:
I'm not sure that I understand.  What is '3 converter?'  I assumed that I'd need a fairly beefy step-up transformer, in the neighborhood of 500W, such as this one on Amazon.
Fritz
Posts 272
Fritz replied on Tue, Oct 13 2020 10:42 PM
On BL 2 which was actually the first real ICE-power loadspeaker from B&O giving an output of 850 watt, it was not possible to rewire the power supply. Both the transformer and the PSU board had to be changed.
The max power consumption on the BL 2 for a 850 Watt output is 70 watt.
A thumrole says that the transformer should be 50 % higher. So a 100 watt transformer will do.
No hum or his will occur, due to the fact that the BL 2 power supply will filter off all noise.
It's nerver mind for the BL 2 if the frq is 50 or 60 hz .
BeoFrederic
Posts 276
Super-helpful, Fritz, thanks.
jk1002
Posts 278
jk1002 replied on Wed, Oct 14 2020 1:39 AM
Besound 2300 and pair of BL2500 needed each their own converter since they were drawing so much power. Initially I was thinking 1 is fine.
cheers
JK
jk1002
Posts 278
jk1002 replied on Wed, Oct 14 2020 1:48 AM
It doesnt open the amazon link for me, but most higher rated converter are for appliances not electronics. Mine were just rated for 40 watts each but they were regulated and speficially for electronics, not appliances.
cheers
JK
BeoFrederic
Posts 276
jk1002:
Ahh, I understand now.  Thanks, JK!
Fritz
Posts 272
Fritz replied on Wed, Oct 14 2020 11:18 AM
A little info:
Beocenter 2300 uses 30 watt, and each BL 2500 (a class AB amp) uses max 100 watt each.
Therefore three trafoes were nedded.
However both BC 2300 and BL 2500 can be rewired for 110 volt.
Page 1 of 1 (11 items) | RSS
