Beosound 3200 ill
This post has 4 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Thu, Oct 15 2020 2:04 PM
Hello
This is not normal, right? It should be steady?
Format: ???
Duration: --:--
It has normally sliding doors, open/close CD-flap, When I give a.opt1 with Beo4 stb light blink once, testmode goes ok, only resetting is giving error. And thats all, nothing else.
Any ideas?
https://youtu.be/V0g_jSVLC1g
Orava
Finland
Posts 991
Orava replied on Sat, Oct 17 2020 12:42 PM
-15V line is swinging between zero and -15V, unregulated between -20V and -22V. Nothing else uses it but CD and display, disconnecting cd does not help, nor changing front face with display and keyboard.
Edit: Analog op amps on input select and pre-amp board also need -15V
ps. there is lot of errors in service manual...
Orava
Finland
Posts 991
Orava replied on Wed, Oct 21 2020 11:24 AM
Nothing draws extra amont of current...
Orava
Finland
Posts 991
Orava replied on Thu, Oct 22 2020 8:24 AM
St.by on/off is going up and down constantly, that explains -15V, but why?
Orava
Finland
Posts 991
Orava replied on Mon, Oct 26 2020 8:15 AM
I guess there is not avialable any flow charts os so about software?
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
