Hi
i just got the Beosound M5 and have connected a record player to it through the line-in.
I am experiencing that even though i swith the M5 off to standby mode using the app it randomly turns back on with a droning kind of bass sound. No music playing just a very loud bass noise.
Anyone who has any clue about how I might be able to overcome that issue?
All help appreciated. Thanks.
Helge
Hi Helge and welcome.
First thing to do....plug out the line-in connected record player.
Does that help?
Hi MM
Thanks for the tip. I had a hunch the line-in record player was the problem.
I’ve unplugged the pre amplifier i had connected and just using the inbuild one in the record player and that seems to have done the trick.
Thanks for your reply.
Kind regards
