Masterlink question
kai
Posts 362
kai Posted: Thu, Oct 29 2020 12:05 AM
Have an old customer where there is an issue with the ml cable, it works fine in the main room but link system wont work, the cable goes outside the house and round the house then up to the attic. This was done nearly 15 years ago which I did not do all has worked until a powerful issue, which has now been resolved, but now link system wont work, I would like to use cat 6a f/ftp cable ext to replace the faulty cable I know this has been discussed many times, but cat6a should work ok? Or would you use masterlink, cost wise cat6a is cheaper and its older kit beosystem 3 to bvis 6, and bvis740 mk as well as a beosystem 2 connected to an old bvis 4, thoughts appreciated
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Thu, Oct 29 2020 9:48 PM
I would step up to CAT7 SFTP 600MHz/1200MHz installation cable which I used to wire up my house when performing a full renovation 2011. Just take a quick look at eBay.de and you'll find the cable there from several commercial sellers.
kai
Posts 362
kai replied on Fri, Oct 30 2020 1:33 PM
Hi thanks for the reply, I will have a look but for his needs cat6a is more than enough
Page 1 of 1 (3 items) | RSS
