Hi ,my beocenter 8500 has recently suffered broken belts on the CD door opening mechanism and no longer functions. The tape door also seems a bit hesitant.Any ideas where I should get new belts from? The bay or perhaps Dillen on here? Many thanks for any help.
If you mean the rubber drive bands that connect the motors to the spindles then I think member Dillen does them.
Regards Graham
