Can you adjust height of record plate on Beogram 5500?
This post has 5 Replies | 0 Followers
freddedw
Posts 12
freddedw Posted: Tue, Nov 17 2020 1:58 PM
Im just guessing here, but when tonearm is closing in on centre of record, it seems like the platter is slightly touching the tomearm mechanism, (below platter), can the height of the platter be adjusted? i only se a "spring" plate where the player mechanism is hanging from, and the mounting screws for the spring plate. and i can only loosen them witch means the platter will go lower not higher., if you understand what im talking about.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Nov 17 2020 6:58 PM
If you cannot adjust it up (screws down) enough to reach a useable height as shown in the manual, something
must be wrong and you will have to look inside.
matador43
Posts 1,373
matador43 replied on Wed, Nov 18 2020 10:38 AM
Beside what is stated in the manual and also widely related in these forums, I can see a lot a pictures where the platter at the very same level than the table. Can't really see how it can work but I've seen it quite often on BG5500 and alike and also on BG12XX, I find it beautiful.
Is there a reason for that?
Thank you in advance.
freddedw
Posts 12
freddedw replied on Wed, Nov 18 2020 1:21 PM
i dont have a manual.. can i find it here somewhere? i think im looking at the correct screws but oím not shure;-)
Dillen
Posts 13,191
Dillen replied on Wed, Nov 18 2020 3:24 PM
Philips head screws holding the leaf springs.
User manuals and service manuals are available for download from our main website here at a small membership fee.
https://www.beoworld.org/manuals_view.asp?pid=299
matador43
Posts 1,373
matador43 replied on Fri, Nov 20 2020 5:33 PM
A little up for y post, gone to moderation but that never showed up when validated.
Thanks.
Page 1 of 1 (6 items) | RSS
