Beocord 2000 type 2921 cassetteplayer, almost dead.
This post has 0 Replies | 0 Followers
Vandenberg
Kopparberg, Sweden
Posts 37
Silver Member
Vandenberg Posted: Mon, Dec 7 2020 4:05 PM
My Beocord 2000 does not start up anymore.
Even the standby led is not working.  The transformator is working fine.
I checked the led and its ok, I measured the voltage on the control board (number 3) and it is only 0.3 volt.
It should be around 5 Volt.
 Also I checked the transistors and they seem to be allright.
Can you adjust the voltage on the control board with potmeters or is it controled by transitors?
Help would be appreciated.
Regards,
Hans.
Page 1 of 1 (1 items) | RSS
