Please please please put me out of my misery. 7wasted hours last night failing to understand how2 change the bely6. There isn't any videos or pictogram or even bullet point for idiots. At this rate, Santa won't be delivering this anywhere.
Thanks so much
Take off the Beograms bottom plate (two screws) and losen the small holders for the cables.On top of the Beogram undo the four screws holding the chassis to the cabinet. Fit the new belt around the platter and let it go in under the edge of the platter.Lift up the chassis a little, just enough to allow you to work in there.From below, locate the hole near the motor where you can see the underside of the platterFit a hook-like tool (I use a piece of solid wire bent at en angle) through the hole, catch the belt and lift it out, over the metal idler pulley.Put everything back together.
