Hello All;
I am a new member here. I had a beomaster 2400, but now upgraded to a Beocenter 9000. Great piece of engineering, and easy to work on for the most part.
My CD wasn't working, but in searching around I replaced the capacitor that was of issue, and it works correctly. The cassette however.... The pins turn, but the two platter wheels do not - I think it is a belt.
But here is a dumb question - How do you get the darn thing out? There seems to be only two screws that I can see, but it still seem to be firmly engaged in the chassis.
Thanks in advance for your time;
Greg
There are three screws.You could be missing the one hiding under the cable bundles behind the tapedrive.
Thought I got them, but I might have been missing one.
Thanks Martin. I will keep you up to date.
