Beoplay A9 gen 2 error in airplay setup
This post has 1 Reply | 0 Followers
beouser645
Posts 1
beouser645 Posted: Sat, Dec 26 2020 1:55 PM
This week my B&O H9 headphones broke down, they are completely non-responsible to reset etc... and now I am experiencing massive issues with my B&A A9 gen 2 speakers, after changing internet provider. I am seriously considering dropping B&O as a supplier all together as those quality issues are simply not accepted. I bought both of those devises in 2017, they are less than 3 years old (!!!). Brought brand new from a B&O store.
Perhaps someone here can help me with my A9 issue.
Device:
B&O A9 gen 2
Issue:
I am running the Bang & Olufsen app on my Iphone, and trying to set up the speaker over airplay. It worked in the past, but I had to re-do this as I am on a new WIFI connection (new internet provider). Other devices managed to connect to my new network just fine - such as TV, alarm system, Iphones, Ipads, printers, etc. But not B&O. What happens is that the app / speaker manages to setup the temporary WIFI connection to which I should connect my phone in the "airplay setup" screen, and the speaker also gives an accepting sound and gives a white light on the indicator. The app then gets stuck in the "waiting for speaker" mode and then it gives up after a few moments, and shows a message saying "unexpected error", and my only option is to press "close". The speaker does after this procedure NOT show up in the app, but I can access it in Spotify as an airplay speaker. That works fine. Then if I restart Spotify, it is gone from there again.
This is what I have already tried:
- Unplugging the speaker, and plugging it back in again
- Resetting the speaker using the factory reset button
- Restarting Spotify and the B&O app on my Iphone
- Reconnecting to my home network on the phone
- Naming the speaker differently in the airplay setup process
- Tried also with another Iphone... same issues
Anyone... please?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Dec 27 2020 8:55 AM
I would try different WiFi channels on your new ISP box. Some B&O products have issues with some channels.
Page 1 of 1 (2 items) | RSS
