Hi All,
Could do with some advice, I have a Beomaster 3500, beogram cd 3500 and beocord 3500, they were all put into storage while I built a house, now 10 years later I have come to set them up, the tuner works, but the other two don`t.
CD Player, no power, nothing at all, any suggestions?
Tape Player, powered up, but wouldn`t play, could hear the motor, found the small drive belt off the motor, refitted that, then it wouldn`t turn inside, causing the belt to jump off, I turned the wheel with my finger and it appered tofree it`s self then run freely, play, ff, rwd, all operated fine, but occationally it keeps locking up again, but that isn`t all, when it is working and it is playing there is no sound from it?
Thanks for your time.
