BeoLab 11 strange sound
Tim84
Munich
Posts 98
Tim84 Posted: Sun, Jan 10 2021 5:14 PM
Hello Beoworld,
I have a problem with my BeoLab 11 I just got recently. It sounds like air is moving but not the way it should. To me it sounds like both drivers of the BL11 are out of sync.
I uploaded an example at wetransfer. perhaps you could help what the problem could be.
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 11 2021 9:15 AM
Listened to the file and it certainly sounds wrong...
Have no other advice then letting a B&O technician have a look.
Beofile7
Posts 150
Beofile7 replied on Tue, Jan 12 2021 2:31 PM
I am actually quite amazed that you managed to record such a bass signal from a BL11. Mine supliments my 11-46 and that is it's only role. I can "just" hear a difference. Now I am wondering if there is something wrong with mine? No way a bass note like that!!!!!
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jan 12 2021 2:42 PM
Beofile7:
Have you played with the settings in BV11?
You can increase the level as well as change the crossover frequency.
Beofile7
Posts 150
Beofile7 replied on Tue, Jan 12 2021 4:57 PM
Yes every part of it is set to max and it is still hardly audible. As a subwoofer it is pathetic. As an addition to the overall sound it has a value. I previously had a beolab 2. I would rate this at 1/10 of the output?
Damn that thing sounds busted.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Tim84
Munich
Posts 98
Tim84 replied on Wed, Jan 13 2021 6:04 AM
I found the problem It seems like one of the drivers is damaged. When I hold the one driver and play music everything sounds smooth and perfect. I think I will repair it myself as a new driver is only 89€ from b&o.
Kitchen: BeoPlay M3
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Sat, Jan 16 2021 2:55 PM
Beofile7:
BL11 cannot be compared with the 2/19/14 sub. It was not intended to be so, it was meant as add on for the BL4/6000/3 to have more bass detail. But in combination with a BV11 it should add to the experience noticeably. Did you set it up as a BL11 in the speaker connection? Also make sure the bass management profile is turned on otherwise the bass will not be redirected to the BL11
Page 1 of 1 (8 items) | RSS
