CDX-2 Reassembly
This post has 1 Reply | 0 Followers
Tim
Somerset, UK
Posts 27
Tim Posted: Mon, Jan 11 2021 11:36 AM
Help !
I've recently done a belt change and LED display change on my CDX-2 - I've not had experience with this machine before and ended up taking it apart far more than I needed (hindesight is a wonderful thing !), in doing so some of the wires that connect around the chassis came adrift, I broke rule No1 - I didn't make notes where cables should reconnect !
Basically I just need to know about the single wire that connects to the lid motor board - (it's next to the only electrolytic capacitor) where does that come from/go to ?
The rest of the multi-pin connectors should be easy to work out.
A detailed photo of the assembled underside would probably suffice - here's my problem in a photo.
Tim
Tim
Somerset, UK
Posts 27
Tim replied on Mon, Jan 11 2021 11:39 AM
Here's my photo
Page 1 of 1 (2 items) | RSS
