Beolab 8000 speaker dropping into standby
This post has 7 Replies | 2 Followers
Biggles1965
Posts 5
Biggles1965 Posted: Sat, Jan 16 2021 11:12 AM
Looking for help please. I have a pair of beolab 8000s that I've connected a chromecast audio to Line in to stream my music. All sounds fantastic for about 1 hour until 1 speaker drops to standby. I can get it to go active by turning up the volume but its too loud for comfortable listening. Once the speaker has done this it will keep up he same issue until I power it down for several hours. It then repeats the fault condition process all over again. I've tried different cables, music sources and devices but no change. I've taken the faulty speaker apart and inspected the foam for rot and the PCBs for damaged tracks, of which there are no signs of damage. Is there anyone who can help PLEASE.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Warm Welcome to Beoworld..
This is a known problem with the early Beolab 8000's prior to about serial number 09459585 when using the line input socket.
The symptom is usually it switches on and off by itself.
The solution is to mount a 0.33 micro farad capacitor rated at 250 volts across the primary terminals of the mains transformer. Such modifications should only be done by an experienced electronics person.
Regards Keith....
Biggles1965
Posts 5
Many thanks Keith
Biggles1965
Posts 5
The serial number is 16156728 type 6802. Would this also have the same issues?
Designed-AV
Sweden
Posts 39
MULTIROOM AUDIO ADAPTER FOR BEOLAB SPEAKER - BL3
Specially made by Oneremote for B&O
Listen to Spotify on your Beolab speakers, connect easily with a Powerlink cable, your speakers are activated on / off completely automatically!
Can be a good solution
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Jan 24 2021 8:27 AM
Dear Keith,
Do you suggest the same solution for my problem?
https://archivedforum2.beoworld.org/forums/t/45317.aspx
Thnx!
laseralex
Posts 240
laseralex replied on Sun, Jan 24 2021 10:07 AM
Designed-AV:
Designed-AV may be a reliable supplier, but I want to warn people that OneRemote took my money last year, let me know the product was out of stock, then stopped responding to emails.   Avoid them like the plague!  If you buy any OneRemote products from Designed-AV make sure they are in stock before you order or you may never see it.   (To be perfectly clear: the problem lies with OneRemote, not Designed-AV)
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Mon, Jan 25 2021 3:59 PM
Dear Keith,
Would you suggest the same solution for my problem?
Thnx!
Page 1 of 1 (8 items) | RSS
