Hi, i have a bv6 last model and it is hard for me to enable the hdmi, so to connect an mirecast.
i would appreciate if someone help me and explain the steps on beo4, so to set up.
Thanks in advance!
Beovision TVs use a different method to access the inputs to most TVs. In the connections menu you have to assign a button on the remote to the HDMI input. This instruction assumes you have nothing else connected to the TV.For example, plug in your HDMI into Socket A. Go to the connections menu an choose AV1, It might say None, arrow right and you can then change by arrow up/down maybe choose V.MEM. When you get to the next screen you should see HDTV it might say NO here. arrow right and change to HDMI A. If you choose V.MEM, when you save and go back to TV, if you press V.MEM on the remote, you should now see what is input on the HDMI.
Stoobie
